BoostKillsStres
TIRE-FRYER VIA HAIR-DRYER
- May 25, 2001
I haven't zero'd out that table yet but possibly plan to. Since the temp range is normally 58-95 degrees I don't think its effecting the A/F much, it does move around more with the MAP hooked up from what I remember. I'm actually not sure which way the fuel correction works but I assume as temp goes down the ecm would try to add more fuel, and from what I've heard it has a max correction of about 10-15% so its not that bigga deal....I hope
Bruce or Dave probably know for sure on this.
I've never played with dfi but I'd assume again that if you used turbolinks boost harness you could send the WB output signal to it just as I have as long as the dfi was similar to the stock ecm in that is has a voltage divider resistor setup on the mat line so you SHOULD be safe from not smoking it but I'm not sure.
