Development continues, just finished putting together a new circuit to get the wideband data to the ecm which provides a completely linear signal to the ecm over the full WB output range of 0-5volts so any wideband can be used that has an analog output in that range. This circuit also provides finer data points so the chip software has even finer control in keeping the A/F ratio on target than what I've been using.
I'll be doing more testing over and after the holidays. The rest of the chip is complete w/ adj spool fuel, adj 2 and 3 gear timing over a 6 degree range from a base(3 extra degrees in 1st, 2 extra in 2nd and main spark table in 3rd+ with the adjustment on top of all these), the learning WB feature which is adjustable where the WB can be turned off and removed if needed and I'll still be on target for the particular boost level being run at the time of learning or an adjustable shift SES light.
As with aftermarket EFI systems, this setup isn't a plug and play deal, it can require tuning of the PE RPM fuel tables so the WB only needs to make the minimum changes to stay on the A/F target ratio just as with VE tables with afermarket systems. However, this depends on how close the initial chip settings are and once that's established at a decent boost level, no further changes are needed. Basically fine tuning the chip tables to a correct level so the WB operates at its best and doesn't have to compensate for radical incorrect commanded fuel in the chip although it can if needed. Directscan logs, which will also have the WB data in them, are the best method to get the fuel tables in line because of the quantity of data you have across the RPM ranges. It also turns out, on a 9 sec pass, the code can make over 100 fuel corrections over and above the base commanded fuel in the chip if needed to keep the fuel curve in line. Its a compromise of doing things fast enough but not too fast as to throw the fuel rich and lean.
So, anyway, that's the latest, tinkering continues, car is running very well and should have a few more locals running in the next couple months as they get their WBs installed. The fun never ends
cya.
