SignUp Now!The bearing numbers are 6760A for sealed power, CB1443P or A for clevite, CR6664AM for king, 6B1443P or A for ACL. The acl P will be an extremely hard to find. If using a steel crankshaft, use sealed power 6-7120CH.
Clevite 1398H is another option for the stock crank. Comes in standard, .001 and .010
Yes they are available in .001 size.Thanks! David. Do you know if the CB 1443P comes in a .001" undersize?
( If using a steel crankshaft, use sealed power 6-7120CH.) Dave this # looks to be a standard width 87 3.8 design. I also noticed that Webers recommends the stock 87 width bearing with all cranks. I guess my question is does the wider bearing really offer a benefit.Thanks for the input.
Of course it offers a benefit. During ignition the rod pushes against the crankshaft and the only thing that keeps the two from hitting is oil.
Lets say there's 100PSI between the two (nice even number) and you increase your loaded bearing area 15%.... the result is a proportional increase in protection. PSI is 'pounds per square inch'. Any time you increase your square inches, you can either tolerate more load safely, handle the same load with less oil pressure... or a combination of the two.
The other benefit is moving the edges of the load closer to the sides of the journal. That will remove some of the rods tendency to try and bend the crank in the middle of the journal. Image our crank journals are 10 feet wide and the rod is 1/2" pushing right in the middle. It will take X amount of force to bend it.
Now image the 10 foot crank journal has a 9.75' wide rod/bearing pushing down on it. It will much much harder to bend that same journal.
