Oct 19, 2012 #1 K kevinm Member Joined Mar 6, 2009 Messages 31 if so about how much boost can you run on a stock block and stock turbo . thanks
Oct 26, 2012 #2 N northerngn Master Monkeywrench Joined Oct 8, 2006 Messages 770 You'll run out of injector sooner than you think data logging will tell you how far you can go...
Jan 16, 2013 #3 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 My opinion, don't waste your time on 42"s. They are equivalent to 28's when running E85. I would go with at least 50's and preferrably 72 or 84's. You are going to step up to bigger pump, hot wire, adjustable fuel pressure regulator, etc. Conrad
Jan 16, 2013 #4 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 Kevin, I see that you have stock block and stock turbo. What have you upgraded on your TR? We need to know exactly what you have. Conrad
Jan 26, 2013 #5 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 What's up? Haven't heard from you. Conrad
Mar 29, 2013 #6 K kevinm Member Joined Mar 6, 2009 Messages 31 Sorry Conrad , been upgrade with hot wire, fuel pump , cold air, thats it, thanks
Mar 30, 2013 #7 J jdpolzin Well-Known Member Joined Dec 5, 2004 Messages 8,531 Do you already have the 42s? Stock downpipe? Stock boost level?
Mar 30, 2013 #8 K kevinm Member Joined Mar 6, 2009 Messages 31 i have 42 but are not installed thing of jus to sell them and buy some 80., ruuning 16lb of boost right now .
Mar 30, 2013 #9 J jdpolzin Well-Known Member Joined Dec 5, 2004 Messages 8,531 80s would be your best bet.
Mar 31, 2013 #11 K kevinm Member Joined Mar 6, 2009 Messages 31 ok so 80 new cip and what else ? thank everyone
