will 42.5 lb injectors work with e85 ?
kevinm
if so about how much boost can you run on a stock block and stock turbo . thanks
You'll run out of injector sooner than you think data logging will tell you how far you can go...
My opinion, don't waste your time on 42"s. They are equivalent to 28's when running E85. I would go with at least 50's and preferrably 72 or 84's. You are going to step up to bigger pump, hot wire, adjustable fuel pressure regulator, etc.
Conrad
Kevin,
I see that you have stock block and stock turbo. What have you upgraded on your TR? We need to know exactly what you have.
Conrad
What's up? Haven't heard from you.
Conrad
Sorry Conrad , been upgrade with hot wire, fuel pump , cold air, thats it, thanks
i have 42 but are not installed thing of jus to sell them and buy some 80., ruuning 16lb of boost right now .
