Will an 83 NA regal have 8445 heads?
mygrain
unregistered
Im stripping a 1983 regal this weekend with a 3.8 non turbo. Should it have the heads that I want? I want to set a pair aside for porting and O-ringing later in the life of my car. I already scored an edelbrock water pump and a freshly recored turbo spec radiator, a good set of doors and fenders and a flat hood. just gotta get around to pulling it all off the car. Not bad for $70. :D :D :D
It should. Pull one of the valve covers and check for the casting number .....8445 under the rocker shaft.
g'luck
