Will BOV effect alky spray?
DynamicGN
I have a BOV mounted right before the throttle body, I'm wondering if this will have a negative effect since the spray is coming before the BOV? Will it seap into the BOV or will it flow evenly into the engine?
Some will come out when the BOV opens. I can smell the methanol sometimes after I let off.
It would be a good idea to route a large hose or something down to the bottom of the engine compartment if you are running more than a 50% mix of alcohol. It could go boom if it was a dense enough mixture and got near the turbine or headers.
