alwayscode390
- Apr 2, 2009
I read on here that the GN pistons bump our compression up a LITTLE.
Will the ported heads lower the compression back down to an acceptable level? They are Champion heads.
# 131996
.020 overbore , block height 9.510, comp. height 1.850
-Head 48cc (stock buick ... i dont know the champion specs) ,
-supposed to keep it at stock 8.5 comp. ratio (for the gns),
-dome volume -29.5
This seems too easy to just pick them and go , isnt there a lot of measurements that need to be taken? Should I be safe with the .020? My car has 150k miles on it, but has strong stock level compression (when tested recently).
I guess I could just let the engine builder pick the pushrods and pistons for me since those figures seem to vary? What do you think? ---
# 131996
-dome volume -29.5
