At one time i thought the TTA had 8.3:1 but i was told i was wrong. I never cc'd a stock engine so i dont know for sure but one that said i was wrong was very credible. There is an easier way to get the info you need. If you have a head off the car you can measure the combustion chamber and what ever the amount LESS than a rwd head you can ADD to a stock GN pistons
Hi Bison,
If you don't have the heads off you can check CR by using a compression gage. Just turn the motor over and divide the compression # by 14.7 (atmospheric pressure). You really only need to check 1 cylinder for this. Even though the CR in the TTA is reported as 8:1 I can see where there would be a difference from car to car. I would say your number above is not really far off, if at all.
I still say a person can run the GN piston with no problem. I have the Buick dish and run 17 to 18 lbs on street gas with no problem. Just sayin.
