will putting a sprag in my spragless convert lower heat
What's stronger a diode or HD sprag?
Does one make it run cooler over the other in a street car?
A mechanical diode is typically stronger than a sprag.
As far as cooling better, I would think they are equal as they perform the same function.
Rob's answer is spot on. A mechanical diode will not fit in many stators though. I use one in my Pro Billet 9" Diode Converter.
whats involved with adding a sprag or a diode in a existing ptc 17 blade non lock convertor..
I called PTC to add a sprag to my converter and its $250 plus shipping. I don't know if a diode can be done I'm going to call today. Problem I have is now I have 1250 in a converter total. Thinking of selling mine and going a different route.
Well 300 for the diode and 200 to freshen it up... Anyone want to buy a converter? Lol
You should have no problem selling it.
Plenty of people still like the PTC. That is until they have to live with it on the street. :LOL:
Someone who runs at the track would be happy to have it.
I heard you're building a track car lollol
I have a sprag in my car due to Dusty's recommendation. Car is 70/30 street/track, car cruises great on long hauls, can't tell a difference between it and my uncles that still has a LU in it, except mine performs much better at the track.
Also, anything over 220* with standard dex 3 you start burning up the additives in it and it won't come back when it cools back off. If you're running dex 3....
I agree with Dave. If it's a street driven car DO NOT bypass the cooler in the radiator.
The water typically in the radiator is less than 190* so you are in essence cooling your trans fluid down to 190 then passing through your auxiliary cooler will drop it further.
This is what I have found works the best.
The water in the cold side of the radiator needs to be much lower than 190*. Like as cool as possible or cool enough to be able effectively cool the transmission oil. This is why proper fans are so important if you have a cooling issue. It's not all about the engine coolant temp.
