Dec 26, 2004 #1 K kmn5 New Member Joined Dec 22, 2004 Messages 18 Just wondering if this may work.... I want to run the pump at say 60% when boost rises to 6psi, and then give the pump full voltage when boost rised to 12psi Does the wiring make any sense or will there be a short?? thanks
Dec 26, 2004 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,968 I don't see a short. No values on any of those parts however nor trigger sources etc. Essentially you shunt the resistor source with relay 2 and full voltage goes to the pump.
