NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Guys,
I have asked before, but I need a conformation from all of you before ordering.
After going back again and checking previous threads, I have determined that the best caliper for my aplication is the Willwood 40-12097R. This is the single piston replacement caliper. Yes??
See attached photo. My combo is as follows........
-Willwood manual MC (don't remember bore size but recommended by Willwood).
-Completely new 3/16" stainless steel brake lines throughout front to back. (no 1/4" anywhere anymore).
-Stainless braided flex hoses at both caliper connections and axle.
-5 PSI residual valve to the rear brakes only. Located just a few inches from the proportioning valve.
-Willwood adjustable proportioning valve.
-Stock rear drum assembly with the standard S-10 big shoe modification stuff. (I hate doing my rear brakes. Brian Cotton does them).
-Stock size replacement cross drilled and slotted front rotors (SSBC or EBC, I don't remember)
-Stock brake pedal assembly with an adjustable push rod and I used the Powermaster mounting pad for the new MC.
Problem- is slightly too much travel prior to brake grab.
Answer- I need to install a NON no-drag caliper.
Please confirm.
Please confirm.
