turbodave231
Moderator
- May 24, 2001
You are looking at a fully assembled new Wilwood Front brake kit for GM G body cars. I installed this kit on my GN racecar only to find that my wheel/tire combo will not work. I immediately put the stock brakes back on the car and did not use this kit. As you can see from the pictures, I have already taken a stock set of spindles, made the necessary modifications and had them powder coated in satin black. My misfortune is your gain! This will save you HOURS of assembly, torquing and safety wiring every bolt. This assembled kit with spindles is READY to bolt on and run (or stop) for MUCH less $$ than the kit by itself.
After some careful weighting, I found that the stock spindle/rotor/caliper combo weights in at 41 lbs. per side. These brakes weight in at 29 lbs. per side for a total weight savings of 24 lbs. Shipping Weight will be slightly over 60 lbs and may ship in 2 boxes.
I'd like to get $570 for this setup. I will consider reasonable offers.
Dave
Dave
