Maybe if there was more follow-up info about "wiped" cams we could possibly establish some reasonable causes?
Seems during the mid-90's there was a terrible rash of aftermarket cams going bad. The consensus then was the cores were not properly heat treated or ground correctly. How accurate this info was I do not know.
The ones that can answer this best is the manufacturers. Don't think I would use a replacement cam unless they gave me a report why the first one failed? This assumes that the manuf. recommendations were followed and their [recommended] lifters/springs used as well.
I am sure we could accomodate a data bank or special forum at TB.com to log information on cam problems. The appropiate and pertinant info would be needed for this to be of value.
Personally, if I had a failure the first thing I would like to know is the surface hardness of the cam. This should be done by someone other than the manufacturer for credibility.
Also, the feedback from the manufacturer concerning the reason for failure and how they handled the situation should be logged as well.
This is a nasty, and expensive, problem we have seen for too long, affecting too many turbo Buick motors. If the factory motors can have stock cams that last 100K+ miles, even running low 11's or so, why cann't the aftermarket cams do as well?
Just my thought for the night, hope it can help.
