Wiring Aradco dual fans to come on at the same time
xtremexnyc
Hello All,
I did a few searches but couldn't find the thread. Someone had wired the fans to come on at the same time and not only when the AC is turned on. Anyone have this info?
Thank you
Kirbans/caspers sells a toggle switch to jump it out or you can do it your self. I'd search for make stock fan run on high. You have to jump it near the ac plug
Thank you all for your replies. I do have the casper hi-lo fan switch if thats what you are talking about. Someone had jumped the pins on the harness for the alradco fan to make them turn on at once when the tstat opens. Even had a pic of which wire was re-pin to make it work.
Is this what you mean?
Sent from my SAMSUNG-SM-G900A using Tapatalk
I have the Racetronix harness and both mine come on at the same time. I also have a manual switch to turn them on early or keep them running in the pits with a battery charger connected.
