I just installed the inovative boost controler, but- Im not sure how to  tie in into the Fast boost read out.  The wiring Diagram says to connect the "green wire to the data recorder outputs and the orange wire to the target boost"
Can anyone help with what wire I should tie into the Fast Harness? Or. do I just leave that unconnected because I can read the boost on the Fast after the run. Thanks Larry
