ok since I am very low on money at this time couple hundred to spend thats about it
I cant upgrade to a bigger turbo, injectors, chip
what I am looking to do though is to max out the stock turbo
I want to be able to run the max psi with pump gas
I want to know if these air/exhaust mods will get me to that point where I can move enough air to use 94 octane
in right now is
THDP 3"
3" test with dump
hooker cat back
RJC power plate
Big Neck intercooler
what I plan to install
Jay Jackson plenum and throttle body
ported intake and matched to new heads
ported and polished heads that are CCed to a larger chamber of 30cc used with some kind of thicker gasket to drop some compression
currently I run 17.5 psi on pump with no knock
what you guys think?
thanks
Carl
in right now is
THDP 3"
3" test with dump
hooker cat back
RJC power plate
thanks
Carl
