I have a 86 GN, which came from a auto-repair shop after the long block (engine) was replace (long storie). Anyway i got the car runing and drive nice . The car was in a mess when i got it, so i had to replace all the vacume line with check-valve. after test drive the car i found a bad wastegate actuator. The boost gauge will go 20+psi at WOT. i replace the actuator and boost is at 12psi (set). I still have to look over the auto-repair work. NO SES light. while driving at 65mph the trans will feel like it disconnect from the driveline (ONLY AT 65) once the speed fall below 65mph i feel the trans connect, and then i can drive to 65mph. then repeat. When the car does hit 65mph i can rev the engine but the power is not tranfer to the wheel to contiune pass 65mph. Any idea?
the owner currently have the car, and is driving around with it. He told me some time the car will go pass 65mph I never experance this when test drive car. so most of the time the car will not go pass 65mph. Car never had this problem before the engine rebuild.
thank you
thank you
