Hello, I guess I got tired of the car running well so I decided to fix a front seal leak I've had for a while.
I put everything back together and now it just spins over.
I did not prime the oil pump. I contacted Mr. Earlbrown and he feels that I should be ok not priming because of the quality of his build on the front cover and I agree because I've had this cover for a while and I am very pleased.
I think that maybe I have installed the cam sensor 180 out although I really don't see how I could have because when I removed the cam sensor I set it a 25 after TOD and I used a permanent marker and made marks so it would go back in the exact way and I put a pair of vise grips on the flywheel to keep it from moving. I also used the cam sensor alignment tool that plugs in with the light on it. I plugged it in before I removed the cam sensor and the light came on. The light also came back on after I re-installed it which makes me believe that it went right back in the same way.
I've triple checked all the connections.
I've checked and it does have gas.
I've checked the fuel is prim
I just wanted to see if ya'll had any ideas b4 I pull the cam sensor again.
Question #1 Even if the pump isn't primed shouldn't the car start.
Question #2 Even if the cam sensor is 180 out shouldn't the car start but run like crap.
Thanks in advance
Thanks in advance
