Daniel Jost
Squirtin six
- Oct 11, 2003
My car has just had the trans rebuilt, and now it will not shift from first to second at WOT. I have checked the gov. spring, and even put the set screw in for added weight, and to get rid of future problems. Also i have replaced the TV cable, and have tried all sorts of settings with it. Some simptoms that i have noticed is that the trans does not lockup in OD until i start to roll in to the throttle only at highway speeds (60-70), and that when it is not shifting if i let up even the smallest bit it will shift into second. I have a "shift kit", trans cooler, with alto red bands, and kolene steel a also if that helps.
Thanks, Dan
Thanks, Dan
