Originally posted by myclone
A vid of a 1/4 mi pass or a pic of a time slip would be nice..
The video and times will be released at the end of the season.
We are busy making money on the streets with this beast.
Stay tuned boys and girls!
SignUp Now!Originally posted by myclone
Originally posted by Syclone Dude
Congrats on the 9.84 robert.
Does anyone know what turbo is on that truck in the video (midwest Syclone)? comp. and exhaust wheel?
BigAl...
Originally posted by KGB Pilot125
so what if you have 2 76GTQ's on your truck?
Originally posted by 86brick
Dave had posted that the turbo is a PT76GTS.... Pretty sure that it is rated at 1100hp at the FW....
Dave, you and your bro would make a crap load of money down here with that truck on the street just as long as you don't pop the hood!![]()
Originally posted by John Wilde
I little Birdie just told me that an AWD v-6 Syclone went 9.84 @ 143MPH on its second or third pass ever. I wonder what it will run with some real boost through it???
Originally posted by top gun
Yes it is true, on the second shakedown pass the truck went 9.84.3 @ 142.6 with a 1.6 60 ft. We turned up the boost on the third pass from 18 to 20 pounds and broke the rear ring gear on the launch. We are very impressed with the low boost performance on a conservative tune up. The new rear should be in the truck in the next few weeks, then back out to the track to throw it down again!
We are anticipating high 140 to 150mph out of this combo when the bugs are worked out.
Hey KGB Pilot, since you couldn't run mid 9's with a REAL Syclone we will show you how it's done.
BTW Dave, I think you and your brother should check out this thread on the Sy/Ty board.....
http://www.syty.net/phpBB2/viewtopic.php?t=38430
Originally posted by mhoover
i know you guys arent counting us out!
MATT
Well better do it soon cause your no longer tied anymore.Originally posted by top gun
http://nalle.puh.org/~sundis/syclonerobban_9.78_229_bysundis_widedivx.avi
i never tried to go fast with a v6. pretty sure that if i wanted to spend a crapload of money on a v6 i could have, just didnt make a lot of sense after seeing my friends a sy owner that has a stroker motor and another friend that has a stage 2 motor. then after hearing about chows stuff when he came to idaho to tune a friends buick i decided that a twin turbo v8 is the way to go. and its still got a sy vin so thats good enough for me.
anyways now that you have proved how fast the truck is what are you guys doing for transfercase? i think that is going to be my weak link. well that and the tranny when i go back to a 700r4. i have talked to the guys at g force but they didnt think that they could match up the transfer case. also leaving with a clutch would be hard on driveline. mine is going to be setup for 5 psi out of the hole and when i shift to 2nd its going to go to 8-10 then when i hit 3rd maybe 12-15. it all depends on the motor and where we dyno on 12 psi we are trying to stay below 850 at the tires for now. in all honesty nobody ever expected these numbers out of the combo not even the original builder. the 821 was put down using 2 60-1 turbos at 12psi. and 32 degrees of timing locked down.
i think that if i can scrape enough money together over the winter i would like to build a low compression 377 or 383 with a dart block. with the new turbos that would make a potent combo on pump gas.
