Would a 200r4 from a 85 GN be a BRF?
Steve
I have a chance to get a 200r4 from an 85 GN and I am curious if it would be a BRF? Thanks
BQ. There is no advantage to one over the other either.
Not to be a PITA, but there is one difference: the servo is bigger in the BRF.
My bad. Your right. But thats it. If anyone needs a stock servo i have several cheap and so does CK
Bq
The BQ governor has a spring on the large weight where the BRF does not. Just remove the spring and the small plastic piece. The spring on the small weight are the same for both. Make the BQ governor same as the BRF--add a large servo and you are there.
Splitting hairs here.
But, the small weight on the gov does not have the hole drilled. So they also shift a little earlier. :cool:
