t3intercooled
- Jul 20, 2004
Well I found out I had a busted rocker and began browsing my options. I thought NOS Rockers or shafts, parts store replacement rockers, used shafts, or roller rockers just going over my options. Then I came across this "diamond in the rough!" :-D
Champion GN1 14 bolt Aluminum cylinder heads, machined with receiver groves for loc wire gaskets, Completely ported, polished, and gasket matched to Felpro 1200 and 1400 gaskets by Champion with matching lower ported intake. In addition it came with 5/16 heavy wall push rods, Accufab upper plenum, and RJC power plate.
Prior to selling he took the heads off his motor and had them checked, jet washed, lap valves, new stem seals, set spring pressures. They have Isky gold stripe tool room 1.550 double springs with dampeners 295lb closed/580 open @ 600 lift, titanium retainers, 10 degree locks, 1.60 stainless exh valves, 1.90 stainless intake valves, and topped off with scorpion 1.65 ratio 7/16 stud mounted rockers.
The combo came off of his aluminum TA 3800 block. With the above combo he ran a best of 9.33 at 143 while running 22lbs of boost on a T70 turbo. He is going with a different heads and intake combo.
Everything out the door $965! :-D
