wtt built 86 cutlass ls car
1 fast ride
Looking to sale roller or tk 86 cutlass ls car has QA1 12 way adj shocks on all 4 corners,qa1 trick springs on the front, harwood 4" cowl hood, QA1 coil spring on the rear, trz anti roll bar, gm 8.5 rear end with 35 spline axles c clip eliminator full spool 373 gear, wilwood disk brakes on the rear,and trz double adjustable upper and lower control arms and has Centerline Convo pro 15x4 and 15x10 with mickey thompson 28x10.5 frame noched and boxed call or text 2283135500 text or message me for motor details
lq4 6.0 ported and milled 5.3 heads ms4 car Bryan tooley springs ls6 oil pump ls2 timing set ls7 lifters texes speed push vic jr intake holley 830 carb
