 - May 26, 2001
We all know from the experience of others that the lower control arm frame mountings need reinforcement. There is no question about that. As I looked at the task of reinforcing those points I realized that the thrust load being transferred to the frame through the lower control arms was being carried by the weak C channels of the mid section of the stock frame. I thought it would be better to lessen that load and carry it to the front of the frame through an additional member. It's a well know fact in the chassis business that an X-frame member does wonders to resist frame twist, and it would also do well to share some of the thrust load from the lower controls arms and transfer it directly to the stronger forward portion of the stock frame.
I also realized that if the intersection of the X was done right I could use it as the transmission mounting also. The whole project really started out as a way to reinforce the lower control arm frame mount, and snow balled from there. The question of how much does it help. Hmmm. The main objective was to strengthen the lower control arm frame mounting points. It does that very well. Being a X-frame member, it controls frame twisting. It triangulates the entire mid-section of the stock frame. It adds more structure to transfer the thrust load from the lower control arms. It adds opportunities to mount other items to it, such as the transmission vent catch tank and intake plenum catch tank.
Bottom line it does a lot of things to help. Does it make a difference on the ET slip? Heck, I don't know. It was just one of my crazy engineering projects.
Don, that is very nice work, which is up to your usual high standards!
We did a similar "X" on my cars years ago when we reinforced the LCA mounts, not a classy as yours, but they do stiffen the frame.
Also, the rubber pads from the trans crossmember have been long gone when we removed all the rubber body mounts and replaced them with my kid's hockey pucks. OK, my "roots" in racing go back to the time before Summit and Jegs, when we had to make-do and modify to get by.:biggrin:
Anyway, I agree, hard to give a number, but my car hooks when many other cannot, and certainly stiffens the entire car.
Don, do not see your diaper or belly pan? They are mandatory on ALL 9.99 and faster cars at the tracks here in the state.
