SignUp Now!What is the best base fuel pressure to run. Also the injector opening time.
I'm thinking a lower f/p, but I have also read about the inj. dribling instead of misting at a lower f/p.
Yes, if moving the VE table by 1 number makes too large of a change, you need more resolution. Lowering the opening time plays with the calculation. It usually requires increasing the VE #'s to get it all worked back out.Dusty you are saying go lower than the .7 and then raise the ve table.
F/P raise?
I have aslo seen that people are running a inj flow rate than what they actually have say with 160lb they are running 150 flow rate. Why are they doing that?
