XFI installation into the dash
Toby_Goodmk
Test Fit officianto
I looked for solutions for a clean install of the XFI and adapter box. I came up with nothing. I added a relay mid stream into the caspers harness for a hotwire into the XFI box so that added to more bulk in the harness. Putting it under the carpet and putting the ECU under the seat was not good. So I went into the dash, made a mounting plate and attached both the ECU and the adaptor box to it. It does make a nice clean stealth look. Got the o2 sensor put into the downpipe as well. Now to get the rest of the adapters from caspers for the MAP sensor as well as the oil and fuel transducer and get the E Dash installed as well.
Nice work and clean installation … but … you can't see the led's on it to let you know if something's wrong...
Claude.
neither can u wen its under the seat where many have it. if there is somthn wrong get out ur laptop cause u can't fix anything without it anyway.
Claude.
Open glove box
Ok, I see …I just thought that the inner part of the glove box hadn't been reinstalled yet but now I understand that you'll leave it off. ;)
and
Mine is bolted to the right side kick panel where I can look at the led's any time I want…(y)
Claude. :)
Claude. :)
mine was too in my last car but wat r gonna see? low voltage? plus u gotta always worry about the passenger kicking it wen they brace themselves wen ur in boost.
installation of the E-dash complete. Wish there was a better looking means of placing it in the car somewhere. I will say that this thing is really cool. Has me questioning if I need gauges anymore. My temp is electric which is the same as coming through the ECU. The boost is manual, as well as the oil... Maybe redundant information maybe not.
What all parts are needed when utilizing the intelligent traction control? Nice job on install.
