Possibly but I would also confirm there is an ignition strategy checked off as well. This is a big one.
Yeah, IPU/XIM is checked off.
would inductive delay play apart in not wanting to start?
SignUp Now!Possibly but I would also confirm there is an ignition strategy checked off as well. This is a big one.
Don't think so. Also make sure the XIM dwell override is not checked off. If so, it will default to the XFI tables that are pre populated with garbage data.Yeah, IPU/XIM is checked off.
I would say your good to go as long as the rest of your previous tune is loaded in. Guess we have to wait 2 weeks to find out.yes, XIM dwell override is not checked off.
Did you install the 2.0 option file? If that option is not installed, the ECU will ignore the crank signal input. You can check by selecting View | Display ECU Configuration. The 2.0 checkbox will be checked if the 2.0 option is installed correctly.
I can't see the 2.051 flash screwing that up can it?
What 5 bar sensor are you using ? I found most of the default map files to not so accurate for the AEM sensors. If you have an AEM sensor I can send you a corrected file. Should read near 98-100 KPA engine off.
Also, If I'm reading your post correctly, it sounds like you changed the map sensor without updating the Map calibration file. This is really bad. You will have to also adjust and rescale your tables and make adjustments accordingly. For example, with a 3 bar map, the XFI will scale the tables with 3 bar being the maximum value. Switching to a 5 bar the tables will have most likely new map values in each row so the VE numbers will need to be shifted or adjusted to the new scale. Same for timing tables.
Allan G.
Mine is linear and the x axis voltage numbers are equally spaced such that the linear line represents linear output from the sensor.Allan one question for you:
is your 5 bar graph a straight linear line? Or does it have multiple points/slopes to it.
