SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
Anyone have any ET/MPH and build results with the Sportsman XFI.
SignUp Now!What were your times with the above setup using SD2?
You have a good running car for the build you have,buy one put a hot tune in it and compare realistically because you have data.its hard to compare a car that has problems and out of tune or isn't optiminzed to a car that is in tune and say its the system.Anyone have any ET/MPH and build results with the Sportsman XFI.
Thanks for taking the time to reply back.I ran a 10.5@130, but I was running 27-28psi vs the 23-24psi at 10.5@128. The 60’ was better on the 23-24psi run 1.5 vs a 1.7. The real advantage is the Sportsman makes adjustments faster and learns the preset target air fuel over 1600rpms. It drives a lot smoother on the street/highway also. With the sd2 you have to piggy back all the inputs through the powerlogger and the more connection points information pass through, the more prone it will be to having issues. I was having to go through the process of cleaning all the connections when it would act up every 6mo. Unless you’re looking to go 10’s or better, I probably would just stick with a 5.7/6.1 TT chip.
Make sure the gate isn't blowing open.I was hitting 31psi and it was dropping back to 26psi at the top of 2nd.
A 67 should make more boost than that look at the gateHD wastegate and manual boost controller are at the max. At 29-31ps
There are a few different ways to close the gate.Wire the gate shut,I've used steel wire in the past,also brian makes a plate that blocks the hole off.I had two throttle cable springs from my wastegate bracket to puck arm on my 6262. What other way would help keep it closed?
I don’t have any dyno numbers yet, but I ran a 10.5@128 with a 1.5 60’ I believe in bowling green. This was on about 23-24psi iirc. Stroked 109, champion irons, 6766bb, RJC 315ic, 215/220 full throttle cam and a 9.5” ptc. The converter is too tight for my car and I am loosing it up right now. The closed loop afr correction works dreams and saved my engine from popping a head gasket. My second fuel pump was going bad and it automatically added 22% fuel to maintain the set afr. The closed loop learn feature makes the drivability very smooth also as ambient temps change. I came from an sd2 and I’m still very happy with it. It seems like the ecu processes information 5-10x faster.
