Does not compare to the spohn or the hr bar. The hardware is garbage. There are no heim joints. They just use bushings that press into joint. That thing will have to bind the way its made. I had one here to inspect and wanted to see if it would fit with my Lpw cover and braces.I opened the box and saw the hardware and closed the box right back up. I would not buy one. Maybe if you went out and got new adjustable heim joints but why do that when you can get the other two with real nice hardware. Just my 2 cents
I'm not saying it compares to the hr bar. I mean it's 1/4" thinner, but for the price it's better than the other ones you'll find that just bolt to the lower control arms and with a few dollars more for some better hardware it's comparable to the spohn bar.
