ZO6 maf , braces, caspers stuff, rear arms
Hey is the knock guage a 52mm? Thanks
led knock is pending local sale , it fits 2 1/16 std pillar pods
davesgn heres a pic of egtsetup , the white sheet is fullthrottles instructions, the probe mounts with just a simple hole drilled below turbo into header , no bung needed
I am afraid I going to pass on the front braces. Thought they were the under
hood braces, not front frame, which i just received from another board member last night.
Thank you and GLWS.
just want to add on the frame braces ,they were the last things i added to the list last night and shouldnt have been included in the free ship
they are 40 + shipping (6lbs large box from 08831) , the last lookup for shipping alone was 18.00 to far west coast
pics of the bars and the fp hood gauge
Got the TPS TEC in the mail today, and just installed it. Took all of 10 minutes maybe. Checked it out, and everything works as it should. Thanks again.
zo6 mass air flow sensor (delphi) 85.00
caspers black face knock sensor , new in box 70.00
caspers tps tech used (have a couple) 30.00ea
caspers audible knock detector (square)new in pkg 50.00
egt setup for power logger .. adapter module with good used clamp on egt k probe 55.00
kenne-bell adjustable fuel pressure regulator (same as accufab only its blue) 75.00
hood mount fuel pressure setup ..( black bracket ,black 2 5/8 cup, autometer pro-comp 5412 liquid filled , braided hose ) 130.00
kirban front frame braces with hardware 40.00
boxed stock rear lower control arms with new energy susp poly bushings 100.00pr
moser 9200 c-clip eliminators (new in box)for stock or 1.400 diam stock replacement axles 140.00
all include usps priority shipping lower 48
paypal ok add 4%
do you have anymore caspers tps tech used (have a couple) 30.00ea
Is this still avalible?
Old thread i dont even have the subscript anymore so i didnt notice it drug back up
yes i have some tps techs left
no on the fuel gauge setup , that went back then locally
only things left from that list
kenne bell regulator (accufab )
tps tech
moser elims
tps tech
moser elims
ill take the tps tech what is your paypal
sorry , sold it and posted so in post 19
and as per post 28 it was sold since it wasnt on the list of what was left
as of saturday all parts listed were sold
just made lots of changes on my cars with a few parts left from up grade downgrades i'll start a new post
heres some of whats not packed away .
i have 3"LTI mafs-- 45
a 3.5" LS1-- 60
accufab regulator (black)-- 75
found another tps tech--- 40
casper adapter stock to valeo dual fans-- 15
reds volt booster -- 30
oil block for the turbo oil feed (brass) 25
dutt neck (new) neck only 50
new cotton 3" ext downpipe with used turbonetics race gate 475 +ship
rjc billet valve cover spacers 80
hand held EGT meter (motorsport innovations ) with k probe 110
1227148 (86-87) ecm 80
stock tb/ plenum (bare with iac mount) 90
moser 9200 clip elims (new) 140
stock I/C and shroud , nice -- 115 +ship
stock oil cooler adapter assembly with hoses and nut-- 65
3" black maf tube (maf to turbo) 50
power antenna tested 110
chrome stock up pipe (from i/c to TB) 50
casper led cam sensor cap 55
