scot w.
GNSperformance.com
- Feb 19, 2005
Well my buddy (zues1) took his daily driver 1986 GN to the local 1/8th mile track last weekend. He drove it 40 minutes to the track with his wife and son with the slicks in the trunk. (running with Stock GN rims in the front and steel rims with 26"x9" slicks in the rear) Got there and this was the out come of ONLY THREE PASSES!
Maybe he will chime in with the exact numbers on the time slips.
Turbo - 6132
60lb inj
Alky control
GEN II
Power logger
3" DP
Pat's converter
EVERYTHING else STOCK!!
FIRST PASS:
17-18psi Boost = it went a 8.35
SECOND PASS:
20psi = it went a 7.97
THIRD PASS:
10psi off foot brake
Spun off the line = 1.75 60'
22psi = it went a 7.87
Not bad droping 5 tenths in just two passes with just a little tweeking! :biggrin: There is still ALOT more on the table as this was with the GEN 2 all at base settings!
And then drive the car 40 minutes back home and the whole trip (there & back) only used a 1/4 tank of gas!! :biggrin:
GOOD JOB MAN!
Scot W.
Turbo - 6132
60lb inj
Alky control
GEN II
Power logger
3" DP
Pat's converter
FIRST PASS:
SECOND PASS:
THIRD PASS:
GOOD JOB MAN!
Scot W.
