I'm looking for one of those tensioners for little money, where are they?You know - you could grab a tensioner for little money
Have you searched for new one lately?
How much will a crank cost me are there better cranks i am not building a race car just a nice street car i can bring my family in and sometimes drag race it low 11 would be enough for me!
What would you sugest! Are the cranks from any 3.8 the same?!
Either you are a dam good mechanic and good with your handsIs the engine out yet? As much end play as you have, I'd suspect that the damper bolt is loose. If you truly have 1/4 inch of play, then the crank & block are junk.
What takes you guys so long to work on these things?
12:40 PM
4:00 PM
They're some of the easiest engines to pull. You can leave just about everything on them. Just unbolt and go!
