Originally posted by Tom87GN
It sounds like my car runs the same as MJRWOOD's ride does. I believe everybody when they say that with 40's and a 307 I should be going faster. Now I just have to find out why.
INTERCOOLER, my chip is from Joe Lubrant, 26 degrees. My fuel filter only has about 3 tank fulls of gas / race gas through it. My sock is a newer non-collapsable style that came with the 307.
Should MJRWOOD and I be looking for kinked fuel lines????
WHAT? Why are you running so much timing? In my research and reading throughout this board, it seems today's culture leans more towards running less timing and more boost. Years ago I ran the Conley Mag-4, which had 24 degrees of timing in it, and it was basically a grenade on 93 octane. Anything less than C16 would be bye-bye head gaskets. Per someone else's claims, I too went 12.60's with stock injector and stock fuel pump, but would not recommend anyone attempting it these days, due to having so many affordable upgrade options.
Anyway, there's been alot of good input on this thread. I too have gone 11.9's @ 112 w/ stock turbo and 36# injectors, Walbro 340, with my O2 still hanging in around 790-820. It's readily achievable.
My comment about the 40's is this: I had the old style "red-stripe" 40's many years ago, and they sucked! At the time, they were one of the few options to upgrade with, but as mentioned above, they had bad street manners, were hard to tune, were fat down low and lean up high. One major drawback was they shot a big straight stream of fuel, as opposed to a nice conical pattern. If you are still using this old style 40# injector, I would do the same thing I did - drop them in the trash! 36# injectors are very easy to find used, (I paid $175), and they have great street manners. They will support at least an 11.70 as long as the rest of the fuel system is properly enhanced.
I forgot,,, what was the question...?
