.030 109 BLOCK ,CHAMPION HEADS
GNXJohn
.030 109 Block billet caps with studs trw pistons stock rods with arp bolts 010 010 on crank balance, Champion Aluminum ported heads with arp head bolts T&D Roller rockers, B&G Ported intake and B&G plenum 70 mm throttle body, Will need a cam & lifters, rings & bearing. $4,000. or part out
Block crank rods & pistons $1,250 SOLD
Champion heads & rockers $1,800 SOLD
B&G Intake complete $850.
And I'm interested in block & rotating assembly. All might be accounted for if you decide to split things up.
QUOTE="marleyskater420, post: 3797878, member: 14364"]How much for the Champion ported heads?[/QUOTE]
May part out
$3K cash for these and I can pick up next week some time?
Sorry off subject, how did this build perform? I ask because my current build is exact other then I’m torn between je pistons or the trw’s. Thanks
