vacuum 6
- Jan 6, 2006
SignUp Now!I should have one around Walt $20. No bolts or gaskets.
Steve
I have a 1.5 and there is no way it's gonna fit. Im wondering whats the biggest myself.Cool let me know.
Also does the 1/2" spacer make anything hit the hood liner?
Just found it , it is a 1/2 inch and both gaskets are on it.
Steve
Walter you going to the club meeting this weekend? If so I can bring it. Or very soon I am taking my trans up to Jimmy's to get a ultra bell put on. Let me know.
Steve
To clear the hood insulator?I have two of those old plenum spacers stacked up together to clear a 4" inlet pipe. I think two combined is probably 3/4 inch or slightly taller with an Accufab plenum and no issues. My turbo sits up higher due to 3 bolt to 4 bolt adaptor.
HTH
Prasad
Ok, I got it. I measured mine last week and I will need 1 inch to clear the up pipe so the 4 inch maf pipe fits thru.No, since my turbo is sitting about 5/8 of an inch higher, I had a hard time clearing the 4" inlet pipe for the turbo under the intercooler up pipe. So I had to raise the plenum in order for the up pipe to clearance turbo inlet pipe. So far it doesn't touch the hood liner.
I still run the stock mounds, I don't know how much taller the motor sits with poly mounts
HTH
Prasad:biggrin:
