I have a CK Performance full billet pro trans. Its about 20 degrees out here right now. When i get the car out and drive it around for about 10-15 mins to let engine etc get up to temp and hit on it, it will start out shifting 1-2 at about 6K RPM which is WAY too high for this car.. Now after i have done some 2-3 WOT runs itll finally come down to about 56-5700 1-2 shift this evening. Yesterday it was almost 40 degrees outside so about 20 degrees warmer then today and the first couple shifts where 6k and once trans was warmed up more i finally started getting 1-2 shifts in the 5400 range. Now the car is also trying to blow the ET Streets off the rims through 1st and 2nd gear as well..... Dunno how much this should effect shift points... 2-3 shift is always right around 53-5400 cold or hot.
My question is does trans temp really have this much effect on the 1-2 shift!? OR is there an issue?
