DougsfastZ
4.1
- Jan 30, 2004
I cracked my two front stock pistons and I'm ready to build the stock bottom end up some. The goal with the car is to be able to support steetable 10.0's. Current mods are in the sig.
This is my list so far:
Stock 109 block
.020+ Diamond pistons with total seal file gapped rings
Stock polished rods with ARP bolts
Stock polished crank
Standard bearings
Machine shop work would be, decked, line honed, and bored .020 over. I'll have them balance the rotating assembly with the flywheel and balancer.
I'm still not sure if I'm going girdled with stock main caps or two center billet caps w/o the girdle. It looks to be about $250 more for the girdle and seems worth it to me.
Anything else I'm missing while I'm in there. Looking to keep the budget around $2k.
Will this support a full weight car running bottom 10's?
Stock 109 block
Standard bearings
