- Aug 1, 2003
86 gn , last pass made in 2006
93 pump gas and alky ,stock shortblock , 200-4r, no slicks or skinnies
drove to track and back 140mile
weight ~3450-3475
launch 10psi , 1.43 60 '
run 24psi for 4 seconds then 23psi the rest
slips are here
http://www.turbobuick.com/forums/at...ut-getting-there-slowly-120306timeslips86.jpg
video (1st and last pass on vid were 4th and 5th run of the day)
Video - A little fun with the Gn's at Atco.
109 stock shortblock , stock pistons rods crank, no caps ,studs ,bolts or girdle
212-208 hydraulic flat tappet
studded ported stock irons , stock rockers and covers, RJC headgaskets
mease plenum , 70mm accufab, stock intake
75# injectors ,stock fuel rail, RTX hotwired injector harness, accufab fuel pressure reg., ATR twin in tank 340s hotwired, stock fuel lines
160 therm , RMI 25-water , fbody rad, valeo dual fans hotwired
champ alt ps bracket , deletes a/c compressor and tensioner , stock pulleys
CAS V2 front mount , 2 1/2 in 3 out
71 GTQ , 70 A/R S cover , precision .85 exh 3 bolt
4" chrome steel inlet pipe (mafless type) with 6x9KN filter 4" inlet
stock exhaust manifolds, poston crossover
ATR SS 3" external gate , test , 2.75 SS TH full length duals ,3" magnaflows
HKS 40mm gate , 5 psi spring , innovative MSBC-1 boost controller
200-4R (good stuff), PTS deep pan , stageright brake, art carr 9" 3600 N/L converter, B&M trans cooler (only)
PTE turbo saver , no oil cooler
AC delco 75 series battery (stock location), stock cs 144 alternator ,reds VB
stock ac delco ign module and coil , MSD DIS-4, MSD 8.5 supercondutor wires
hd chromoly driveshaft , spicer yokes
8.5 rear 3.42, moser spool ,33's ,elims, studs, alum drums, stock upper arms , boxed stock lowers (all stock bushings), HR parts rear sway bar (no front)
stock rr springs (no bags), eibach front (-1"),
nothing fancy about the shocks
276/60-15 MT radial ET streets (drag radials) inflated 22psi (no slicks)
235/50-15 fronts on 15x7 western mesh aum rims (no skinnies)
6 point roll bar (no swingouts), SFI trans blanket, 5 point 3" belts , metco driveshaft loop, steel valve stems
other stuff
vacuum brakes , stock interior pw/dl/tilt /pseat/deck rel/ p-ant/delco cassette , CF hood , token frt and rear bumpers, rr alum support
fuel .
93 wawa gas and alkycontroll PAC dual nozzle (methanol)
engine management
stock ecm (modified drivers for injectors) , turbotweak 5.4 chip , translator+ LT1 3" blow through mass air flow sensor , denso O2
engine monitor /logger
gnx 8 gauge dash ( boost /knock/tach/speedo/volt/water/oil/fuel level
scanmaster 2.1
directscan 1.52
Innovate LM1 wideband
weight ~3450-3475
slips are here
other stuff
fuel .
engine management
scanmaster 2.1
directscan 1.52
  Kinda reminds me of 9 years ago when I was told how F.O.S. I was on the gnttype BB when I ran an 11.16 on a BF Goodrich 275/60-15 (Touring Radial). Even after scanning the timeslip and having multiple witnesses I was still smoking the cheeba. Again congrats, glad to hear you are posting up your results instead of keeping them to yourself. As for the critics, pizz on em, they probably think the lunar landing is all a hoax too.................
