- Aug 1, 2003
86 gn , last pass made in 2006
93 pump gas and alky ,stock shortblock , 200-4r, no slicks or skinnies
drove to track and back 140mile
weight ~3450-3475
launch 10psi , 1.43 60 '
run 24psi for 4 seconds then 23psi the rest
slips are here
http://www.turbobuick.com/forums/at...ut-getting-there-slowly-120306timeslips86.jpg
video (1st and last pass on vid were 4th and 5th run of the day)
Video - A little fun with the Gn's at Atco.
109 stock shortblock , stock pistons rods crank, no caps ,studs ,bolts or girdle
212-208 hydraulic flat tappet
studded ported stock irons , stock rockers and covers, RJC headgaskets
mease plenum , 70mm accufab, stock intake
75# injectors ,stock fuel rail, RTX hotwired injector harness, accufab fuel pressure reg., ATR twin in tank 340s hotwired, stock fuel lines
160 therm , RMI 25-water , fbody rad, valeo dual fans hotwired
champ alt ps bracket , deletes a/c compressor and tensioner , stock pulleys
CAS V2 front mount , 2 1/2 in 3 out
71 GTQ , 70 A/R S cover , precision .85 exh 3 bolt
4" chrome steel inlet pipe (mafless type) with 6x9KN filter 4" inlet
stock exhaust manifolds, poston crossover
ATR SS 3" external gate , test , 2.75 SS TH full length duals ,3" magnaflows
HKS 40mm gate , 5 psi spring , innovative MSBC-1 boost controller
200-4R (good stuff), PTS deep pan , stageright brake, art carr 9" 3600 N/L converter, B&M trans cooler (only)
PTE turbo saver , no oil cooler
AC delco 75 series battery (stock location), stock cs 144 alternator ,reds VB
stock ac delco ign module and coil , MSD DIS-4, MSD 8.5 supercondutor wires
hd chromoly driveshaft , spicer yokes
8.5 rear 3.42, moser spool ,33's ,elims, studs, alum drums, stock upper arms , boxed stock lowers (all stock bushings), HR parts rear sway bar (no front)
stock rr springs (no bags), eibach front (-1"),
nothing fancy about the shocks
276/60-15 MT radial ET streets (drag radials) inflated 22psi (no slicks)
235/50-15 fronts on 15x7 western mesh aum rims (no skinnies)
6 point roll bar (no swingouts), SFI trans blanket, 5 point 3" belts , metco driveshaft loop, steel valve stems
other stuff
vacuum brakes , stock interior pw/dl/tilt /pseat/deck rel/ p-ant/delco cassette , CF hood , token frt and rear bumpers, rr alum support
fuel .
93 wawa gas and alkycontroll PAC dual nozzle (methanol)
engine management
stock ecm (modified drivers for injectors) , turbotweak 5.4 chip , translator+ LT1 3" blow through mass air flow sensor , denso O2
engine monitor /logger
gnx 8 gauge dash ( boost /knock/tach/speedo/volt/water/oil/fuel level
scanmaster 2.1
directscan 1.52
Innovate LM1 wideband
weight ~3450-3475
slips are here
other stuff
fuel .
engine management
scanmaster 2.1
directscan 1.52
