10.50s???
007gn
How fast do you guys think my combo will run?Im hoping to hit 130 or better goin through the traps. My combo is 30 over 4.1 ported irons 215/220 Hyd.rllr forged pistons stk crank n rods with 2 center billet mains tt chip 80lb injts 6766cea Brian hoffer 200r4 9.5ptc non loc up 3.42 / 295-50-15 Micky drag radials...tell me what you guys think & what to expect if it breaks I'll just do another 1
I'd expect 130mph@22psi. 140mph@29psi. Feed it plenty of octane.
That's what I was hoping you would say Bison.Will alky n 110 turbo blue get it done or should I just run a double pumper with straight 110? My heads n turbo would always go thru the 1/4 at 127mph before on my stk stroke 109 running a comp 212/212 Hyd rllr.also would I benefit any by swapping over to gn1 aluminums?..thanks Bison.
Id scrap all fueling ideas and go with straight 116+ octane. Not 110 and i wouldnt run alky either. The GN1 aluminum race ported will drop the pressure ratio needed to get it done down to about 2.6:1 and be as quick as the iron heads. Throw some voltage at the pumps.
