10 sec build-up or tsm (pictures)
87buickracer
Finally getting motor together.Engine is 40 over/girdle/218 billet roller cam/ported big valve heads-intake/72lb injectors/pt72 turbo/70mmtb-pl-pp. may change turbo and injector combo later.
10 sec build or tsm
Well if the v6 blows,the v8 will be next,like the one pictured(sweet).
Just a little bit of advice if you have not taken care of it already.....you need some type of thrust system on the back of the face of the cam or it will drive itself backwards into your block and cause MAJOR problems (broken lifters etc).
10 sec build or tsm
Thanks,I haven't got the rest of roller cam parts yet.Who would you recommend for all the nose end pieces for cam?
