- Aug 1, 2003
seems every one want to praise you and and tell you your doing great
im not one of them
ill say it slowly so you can understand ...you're still slow , the springs were a waste and advice to lockup a nine inch at wot is rediculous and times show it did nothing , it will only lead to increases trans temps from the slipping clutches and a burned out lockup clutch leaving you nothing for the highway
something isn't right scottie.... and weres the data logs ????
work on the tune and quit trying to run 25+ psi until you get it straight
im not one of them
