Cal, when are you coming back to Kansas City? Need to save some pennies and have you Tune this thing. Lol
I'm tuning a Kansas car next week. Unfortunately, he's meeting me in south Georgia
SignUp Now!Cal, when are you coming back to Kansas City? Need to save some pennies and have you Tune this thing. Lol
So, if using my 120lb injector example from my earlier post, would entering in the 12.0v=0.82 ms get you real close? Then I guess you can adjust as needed.
Sorry I meant to say MAP not MAF. The value is between 5.5 to 8 depending on the idle.What is your MAP value @idle?
Teflon. All of them. All from AeromotiveAre they Teflon or rubber AN lines?
That is your problem. It should be a negative value. Are you sure you have the correct MAP sensor?
Well I feel stupid Guys. Those values are - sorry.That is your problem. It should be a negative value. Are you sure you have the correct MAP sensor?
Yes. Many times. Next step is to come up with a smoke machine.Have you check for vacuum leaks or cracked or loose IC hoses?
I have checked the IAC and it is working. I have even put one in with the end ground off basically no plunger to try to get more air on start up. No help.I was also thinking IAC. I find it odd that it would start fowling plugs in colder weather.
The sensor shows it's reading on the program, and is in line with my gauge.Have you checked to make sure coolant temp sensor is functioning?
I chased an idle problem for a whole year. It drove me crazy. I messed with the VE map, AF map, timing trim, just about everything. I was adjusting the idle screw up and down and constantly found that just when I thought it was perfect, I would drive the car and come to a stop and it was all messed up again.
Technology spoils us. We expect the answers to be found somewhere on that flat screen. I'm embarrassed to say it was the IAC motor. I should know better. I felt like F'n JERK.![]()
I know what you mean Joey. This thing has drove me nuts, and just when I think I have it figured out it does something else.
It's sickening I had it so good with the 83's all but the cold start. I changed the injectors so I could start playing with it, and it's all crazy now.
I have also noticed that when I'm driving it and let off the throttle it goes pig rich bad, and it didn't do that before.
I imputed the injector numbers in it and it seems better as far as not being lean but it still goes pig rich after letting off the throttle.
I think that might be another table to adjust just have to figure which one ( still learning).
I do know the pulse wd numbers I had was way off from the new ones.
