SignUp Now!Did this start suddenly? If you have that big of a leak, it should show in your BLM readings. Sounds like the classic boost solenoid issue.Underboost said:I can only get 10psi of boost. I have checked the hoses, turbo blades, puck on the down pipe, plenum gasket, disconnected the waste gate still 10psi, checked boost gauge with another boost gauge, put new headers on, and checked all vacuum lines.
I am about to pull my hair out.
Jerryl said:Did this start suddenly? If you have that big of a leak, it should show in your BLM readings. Sounds like the classic boost solenoid issue.
---------------------------Underboost said:I have the RJC Boost Control that takes place of the stock solenoid. but thank you
I have taken the vacuum line off the turbo. So that bypasses the rjc and still nothing.
OKBuickTurbo said:Broken wastegate spring?
OKBuickTurbo said:Test all the vac lines that would feed the boost gauge for leaks too. Mine was leaking at one of the rubber connectors on the vac block on top of the plenum.
