15x6 draglites up front what BS??
xXch0dyXx
Weld Racing Draglite Wheels: WLD-90-56346 - summitracing.com
would these be the ones i want to order with the correct BS? I had the 3.5" on the front but there was too much slush, so i wanted to get a little wider on the front and just wanted to make sure on the BS.
On a side note, my 275/60/15 on the rears were rubbing a little when i had the tire pressure dropped, how to i measure the BS on thsoe to see what i have? I bought the car with them on, so i just want to know what i have.
TIA
Yes, those look right. 3.5" BS is what you want. I have run both 15x5 and 15x6 Welds in the past and both had 3.5" BS and fit perfectly. Don't forget the metal valve stems, might as well knock that NHRA rule out now while you're at it.
I prefer and have used these on all of my race wheels in the past.
Summit Chrome Tire Valves: SUM-G1957 - summitracing.com
HTH
Patrick
