- Nov 30, 2009
Does anyone know if Turbo Tweak is making a 6.1 wideband chip for 160 lb injectors ???
SignUp Now!Does anyone know if Turbo Tweak is making a 6.1 wideband chip for 160 lb injectors ???
Low 10's @130 right now , 3700lbs , has more in it .How much power does the car make now? Maxing out 120s is not "easy."
How much alky are you going to introduce with e85?Everything is in my signature .
Twin racetronix 340's , -8 feed -6 return , Caspers Voltbooster ( 15vdc to the pumps ) 6.1 chip Powerlogger .
E85 , logging FP , 10.8 target AFR ( rock steady , chip controlled ) , 80% duty cycle .
I'm working with Mr Spool and adding my Alky injection back on to supplement the fuel system and increasing base fuel pressure .
Not sure yet . Uncharted territory for me , that's why I'm going to work with Mr Spool to get it dialed in . That guy sprays a whole lot of alky and has been for a very long time !!How much alky are you going to introduce with e85?
Oh yes i'm aware lolThat guy sprays a whole lot of alky and has been for a very long time !!
I see your from Long Island , I figured you would be !!Oh yes i'm aware lol
Post a screen shot of the second pump coming on fuel psi wiseLogging , yes , FP at WOT is 79 - 80 psi with a base pressure at 49 psi . Pumps are keeping up .
I only have a few logs from BG last year and my Powerlogger had defaulted to " base " settings in which my wideband O2 wasn't AEM inline and my aux inputs #1 & #2 defaulted to voltage ( from the sensor ) instead of pressures . I can say that the second pump would be turning on in under .5 seconds at 15psi . Do you think the second pump isn't coming on ?? In past logs when fuel pressure was recording I never saw a jump from the other pump but boost was rising very fast to 30psi and FP rose right with it . The BG logs were not very helpful .Post a screen shot of the second pump coming on fuel psi wise
