16v system
8scbuick
Would I be able to run a 16v system in my car.Would the fast system be okay with the extra voltage.I know Craig talked about the 16v system and the data logger issue.
Tony
16 volt systems are fine. They are quite common actually. I'll be using one myself.
Once the charger is on though the voltage is up around 20 and it becomes a bit much for some devices. The ECU would be OK, but the data logger doesn't like it. If nothing else, it's not a great idea to have the car turned on with a 16 volt battery charger anyway.
