iraceitall
As long as the compressor wheel diameter stays at 1.835, and the housing at 1.863, and no grinding or polishing is done.
4100 feet sucks for that tiny compressor. If that fwd 4 cyl was better setup to accept turbocharging stock then it could easily surpass a larger engine. Like having an open plenum intake setup like an LC2, blow through setup and or it's an ohc engine. These things make a huge difference when trying to get more out of less. The intake setup on the b4b cars was so restrictive it probably wouldnt matter much what head work was done or what cam is used. I'd for sure be building around s lot of cyl pressure though. I'd be right at 9.3:1 and running timingiraceitall said:Housings don't have a casting number that they track. The small bit of latitude we get with turbos, along with them having no way to regulate the amount of boost we use, is the advantage turbo cars get. It's also my best friend since my home track is 4100ft.
If a FWD, 3200lb 4cyl turbo can run the number, why can't I?
Riviera
1983 T-Type Riviera
231 carbed turbo,750 Q-Jet
T-3 stock turbo
3700lb
The car now runs in BF/S NHRA Stock Eliminator.The index is 14.95 in this class.The car has gone 13.60@102mph with 22psi of boost with c16 and good air
The motor is blueprinted to NHRA spec.I have been torn down 3 times and have been found legal.See spec in NHRA rule book.
Some of the parts...JE pistons,Lazer cam,Manley,Jesel,Stef,MSD,Meziere,Moroso, PTC,Air Lift,QA1 etc.New motor being built for next year with some new go faster parts and massaging.
Tony
In your case I'd think it would be more like the porn addict watching the puter.welcome to B4B, there is nuthing fast about these cars until you really kick them in the ass. Why do you think we spend most of our time all alone in here like little crack heads in a dark garage corner?
In your case I'd think it would be more like the porn addict watching the puter.![]()
Here's some inspiration:
This was from the turbobuicks.com board. Tony Massari was his full name. I read the car hit the wall and has not ben run since.![]()
I wonder if you can find modern set of impellars for the turbo that are the stock size just a better pitch
