1986-87 Buick GN/T Type Low Mileage Take-Offs & Aftermarket Parts W/Pics
tbirdv6
Parts are off low mileage turbobuicks I've had in the Sunshine State of Tampa,Fl, so if you see a sign of oxidation (surface rust) it will come off with some steel wool.
At this time it I've haven't done my homework on what these parts are worth until you make me an offer + I will give better price on YOU purchasing more than 1 part.
All Parts are used unless specified & sold as is.
I accept Paypal (turbobuick4@yahoo.com)
You can call me with any questions
Fred @ 813-451-4242
I'm trying to be fair who gets what first,but between PM's,POST's,Emails, & Phone Calls ,someone going to get upset because they said they inquired 1st.
Communicate & make payment ASAP & the parts are yours.
Here is a description of the following parts in the pics provided:
First 2 pics are as follows left to right:
Rear License Plate
Front License Plates
Parking Brake
Up Pipes-1 is drilled for Alky, the other is not.-UNDRILLED 1 is SOLD
2-Intercooler Mounting Brackets,1 is cut,the other is not.
More Seat Trim Pieces
Brand New Hood Lift (1)
T Type Grille (daily driver condition)
Rear View Mirror W/Map Lights (a must for T-Top Cars)
ECM Holder/Cover-SOLD
Firewall Passenger Side SheetMetal
A/C Control Head
Blue Center Console Door
Brand New-Cam Button(comp cams) & Cam Tensioner W/Spring (cloyes)
Valve Cover Oil Neck w/small K & N Filter (can also use filter in front of passenger side valve cover)
2-End Caps for Spoiler
2-Retractable Seat Belts
12-Brand New-Sealed Power Lifters HT-969-SOLD
Brand New-GM Hose
2-Cone Filters,1 has filtered opening at the end for more air
Description of #3 & #4 pics:
Brand New Signs (both are one of a kind)-12" x 8" , Great for Car Shows!!!
1-Made of Steel w/honeycomb backdrop, "Look,But PLease Do Not Touch" (GN insignia)
1-Made of Plexiglass, "An Antique Auto Is Like Another Man's Wife-Look and Admire, But
DO NOT TOUCH(GN Insignia)-BOTH ARE SOLD
Overflow Reservoir w/Cap & Hose.
2-Stock Air Intake,Both have K & N Filter Inside,1 is complete,the other is missing the bolt to keep the upper/lower halves together & the plastic duct as shown in pic.
1/2" Plenum Spacer
Rear Speaker Adapters (convert your puny stock speakers to 6x9's)-SOLD
2-Wide Band O2 Sensors (its what Innovative uses)-SOLD
4- ACDelco GNX O2 Sensors (quicker than stock ones)
Water Hard Pipe (for lack of terms,runs along passenger side intake)-SOLD
Stock Wastegate
Heater Valve
Fuel Pressure Regulator
Fuel Pressure Chrome Line
2-Turbo Oil Feed Lines-SOLD
4-Misc. Power Steering Lines and or Hydro Boost Lines (was going to convert to get increase pressure from power steering to Powermaster)
Wire Harness Cover-SOLD
Negative Battery Cable-SOLD
4-Rubber Door Bumper-SOLD
Brand New GN logo Valve Stem Caps-Set-SOLD
2-EGR Valve complete & 1 cover
VDO EGT Guage
Autometer Oil Pressure Guage
6-Usable Downpipe Gaskets-SOLD
Lug Nuts-OEM complete set+a few extra-SOLD
2-Front Grille Springs-SOLD
T Type Badge-SOLD
Motor Hoist Bracket-SOLD
AC Pressure Switches (and a few undentified others)
3-Turbo Breather Covers- Kirban Style & K&N (small) Sold
View attachment 159616View attachment 159617View attachment 159605View attachment 159606View attachment 159607
Last or considered the other pic:
Thermostat Housing w/Hold Down Bracket
Vacuum Block
Breather Hose
New-Passenger Side Parking Light Bezel (metal)-SOLD
Kirban Valve Cover Breather-SOLD
K & N Oil Breather
Breather (small) Fits in front of passenger valve cover
4-Metal Headlight Bezels
Package of Window Moulding(trim) Clips
Coil -SOLD
Transmission Inspection Cover
Chrome L/R Bezels
Tire Irons (2 different lengths)
Spare Tire Hold Downs
Vent/Ac Door Actuator Cables
2-Stock Tranny Pan, 1 has zero dents on bottom,the other has 2 small dents on bottom
Flywheel
VSS Sensor
Stock Oil Pan-Zero Dents-SOLD
S Hoses
Misc Seat Trim (feet where bolts down to body)
Passenger Exhaust-has a crack
3-Turbo Washers (Locks down turbo for Clocking purposes)
View attachment 159605View attachment 159605View attachment 159606View attachment 159605View attachment 159607
I'm interested in:
AC-Delco GNX O2 Sensor (price for 2)
pm me or post $$?
Thanx!
D
WATER HARD LINES ?? AND A SET OF TURBO VALVE STEM CAPS SHIPPED TO 33317
I'm interested in:
pm me or post $$?
Thanx!
D
How many trim pieces do you want?
Less trim pieces (not knowing how many you want) so far $65 shipped
FRED
when I pick up those bucket seat track covers and those sign I would like to get i or to of those upper plenum gaskets..... thanks fred....
p.s. and a set of tire valve caps if you have a extra set sitting around....
The valve caps I have has the GN logo on them (brand new)
I don't have upper plenum gasket- it's a phenolic Plenum 1/2" spacer
What Time of day are u thinking?
FRED
